Die Standard-Installation von PostgreSQL beinhaltet keine Replikationslösung (Stand August 2012). Hierfür gibt es jedoch einige separate und teilweise frei erhältliche Programme:
- Slony1
Replication is possible through the „Slony1“ PostgreSQL database replication solution, which is not a part of the core PostgreSQL distribution.
[https://www.slony.info/]
- Tungsten Replicator
Tungsten Replicator is a high performance, open source, data replication engine for MySQL and PostgreSQL.
[https://www.continuent.com/solutions]
- Daffodil Replicator
Daffodil Replicator is data replication software that synchronizes data residing on corporate backend databases and desktop databases operating in the network. Daffodil Replicator performs data replication based on the ‚Publish and Subscribe‘ model (in client and server architecture). A publication is a collection of one or more tables required for data replication. A subscription is a copy of tables involved in publication on client side.
[https://sourceforge.net/projects/daffodilreplica/]
- Bucardo
Bucardo is an asynchronous PostgreSQL replication system, allowing for both multi-master and multi-slave operations.
[https://bucardo.org/]
- Postgres-R
Postgres-R is an extension to the relational database system Postgres providing efficient, fast and consistent database replication.
[https://postgres-r.org/]
- Postgres-XC
Welcome to Postgres-XC, the only known PostgreSQL cluster solution which provides for both read and write scalability.
[https://sourceforge.net/projects/postgres-xc/]
- SymmetricDS
SymmetricDS is open source software for both file and database synchronization with support for multi-master replication, filtered synchronization, and transformation across the network in a heterogeneous environment.
[https://symmetricds.org/]
Wichtiger Hinweis: combit hat diese Software nicht getestet und kann daher weder eine Empfehlung noch eine Zusicherung für die Verwendung der Produkte abgeben.
IDKBAD001175 KBAD001175
